- Joined
- 20 Oct 2019
- Messages
- 12
- Reaction score
- 0
- Country
My boiler is giving an intermittent L/F code. This is to do with ignition, right?
So the plumber came round, had a look and said the boiler is knackered because of "shedding" in the main heat exchanger. He said this would cause overheating, which would cause the boiler to lock out.
The only problems with this conclusion are :
He did not witness the fault code.
The fault code for overheating is L9 and not L/F
A blocked heat exchanger doesn't prevent ignition, rather the fault occurs after a successful ignition.
I would have thought he would examine the condensation pipe and trap first, no? Then maybe the igniter and flame detector?
So, is he having a laugh?
