I have a glowworm gravity fed back boiler. In the summer we had to have a new hot water cylinder fitted in the loft, since then the central heating has worked fine but we cannot get any hot water.
Last week a plumber came and banged about for a bit said he had managed to remove a small amount of air from the system but thought the pump had failed ( no vibrating pump half cold half hot) and needed replacing even though the central heating is working fine.
After he left the water heated up fine for two days and is now cold again.
The same plumber is due back to try again can you help......PLEASE
PS. In the summer to heat hot water only we have to switch off the upstairs radiators as these still get hot, does this mean we need a check valve? if so one was never fitted as this has been the case since the heating was installed.
Again many thanks
Again many thanks
