I'm trying to refresh my sub-floor as some of it is water damaged and as I've got my carpet up it seems like the perfect time. I've tried to do research into this but it's hard to find reliable info.
So far I've found I can use either Plywood, OSB or Chipboard for my floorboards and I'm getting the impression 18mm Structural Plywood is the best but it seems incredibly expensive.
Is Plywood actually the best to use? If so, I may just make the investment but I just want to make sure it's actually worth it.
Also, how do you guys advise removing the sub-floor? I could potentially pull up the skirting board.
