Windows XP keeps System Restore points for 90 days, which, on average of one point every 24 hours is quite a lot of space being taken up on your HD.
If you think about it, any problem that you may have that needs you to restore to a previous time will normally be cured by restoring your computer back to a date about 1 week ago at the most. Any faulty installed program will cause problems within a week of being installed and if uninstalleing does not cure the problem then a system restore normally will.
To reduce the number of days that restore points are kept, thus freeing up space, can be done using a simple .vbs script.
Follow this link and click on the:
XPSystemRestoreLife.vbs (2nd one down)
http://bertk.mvps.org/html/srscripts.html
When downloaded, extract the file, then double click to open it and set the days to 45 instead of 90.
That will free-up half the sapce that it used.
dave
dave
