Is testing possible.....
12 Sep 2006
Newcastle upon Tyne
on a T622cw with regards to the stats or elements as i have tried drill and nail methods and still no heat, though the drum turns as normal.
I have tested the filaments/elements with a multimeter and all is good, but still no joy with any heat. Antone got any clues as to what could be causing this?
depends on how you tested it and what the results were.
what were they?
Basically unplugged the looms from the filaments and the spade connectors from the stats and then tested with the multimeter on ohms and all gave good readings so now i am stuck. Any clues
Although an engineer would look for the correct reading for the element it's safe to say that if you get continuity across the element you should get some heat from it. As you've tried bypassing thermostats (not recommended as these are easily checked with a meter) and still get no heat you need to check and see if there's a thermostat on the exhaust side of the dryer.
Normally these are on the front of a dryer or on the air chamber coming from the front of the machine. (very few machines don't have an exhaust stat). If fitted and open circuit then you'll not be getting power to the heater.
If no other stats are fitted and you still don't get power to the heater you need to start checking wiring back to the timer.
If everything else checks out fine then it can only be the timer at fault.
