Running a spur from bedroom ring main through this volex 13A RCD FCU (30ma) to this Honeywell 1.8kW Quartz Bathroom Heater? With the volex being in the bedroom (cupboard), and then the cable a straight run up the wall, across the attic, and drop down into the heater? (Using one continuous run of 2.5mm squared cable). The cable length would be about 8 metres all in.
