- Joined
- 5 Jul 2011
- Messages
- 223
- Reaction score
- 1
- Country
I used to have a Raeburn range cooker with boiler which was in the house when i moved in. It was crap as a cooker so had to go. I had an IDEAL Logic heat 30 condensing gas boiler fitted in a different location with in the house. At the same time the system was split into a dual system so I can control upstairs and down stairs heating independantly.
The system has never appeared to be 100% because we used to get a no flow fault code on the boiler. Eventually I had an IDEAL engineer check it as my own plumber couldnt fix it. He opened up the bypass valve and that seems to have fixed that problem.
The other problem no one can fix is the start up noise. Everytime the boiler starts up after the heating has been off for a long time usually over night there is a horrendously loud noise like a blue whale being played at a very slow speed, wakes the kids up every morning!
I presumed its air in the system? Once running everything seems ok. Im worried something is being damaged and its obviously not right.
Any ideas?
Any ideas?
