I recently replaced the lock/lever unit on my front door, to fix the old faulty unit. Unfortunately, the new unit did not exactly match my old door frame so I had to make some new holes and leave the old holes in place. Although I tried to fill them using white(-ish) epoxy putty, the appearance is *far* from perfect. What I am wondering is whether I could glue in a PVCU blanking plug, which would at least be pure white even if it wasn't completely flush.
Looking around, I can't see any PVCU filler that would do the trick, so my question is this: is there actually a filler that I haven't found or will the PVCU cement used for waste pipes do the trick to glue a plug in place?
