Thanks it's laminate worktop, what is a splashback made from?Is it chipboard? Any moisture that inevitably will get past the silicone at some point and into that chipboard and it'll be blown and unrepairable in no time. There's a reason splashbacks aren't made from chipboard.
Thanks, so behind an electric hob is ok?You can't use it as a backsplash/ splashback behind a gas hob as it's combustible material just incase you were thinking about doing that.
Usually something impervious to water ie tiles.Thanks it's laminate worktop, what is a splashback made from?
Yes, but it will look rubbish imo, get some toughened glass.Thanks, so behind an electric hob is ok?
