Hi all,
Can anyone advise whether the wall highlighted in red below (above a stairwell) is normally holding up the ceiling above? We're in a fairly standard 1930s semi.
The wall highlighted in red is showing some pretty serious cracks, and we'd like to if possible remove and replace with a stud wall. Like all other interior non-load-bearing walls we've identified so far in our house, this wall is built of a wooden framework that's been filled in with bricks and then plastered, so I'm hoping it's either not load bearing, or certainly not holding up anything other than the ceiling in the adjacent rooms.
At the moment our plan is to find out if it's significantly load bearing, if it's only holding up the ceiling can we get a stud wall build capable of holding this same weight?
Thanks,
Russ
Thanks,
Russ
