With respect, I really don't think such pedantic / 'trying to be clever' comments do anything to aid our discussionsSince it does not supply electrical equipment, it is not a circuit, in the same way the lighting circuit is not a circuit unless at least one light is switched on. ... So every time you switch a light on, to make a circuit, but not a new circuit, the circuit has been made before.
We all 'know' what is meant by a 'sockets circuit', 'cooker circuit' or whatever, and continue to call it that even if there are no connected and 'switched on' loads to complete the (electrical)'circuit'.
Same comment as above., Again, I think we all 'know' that there is no intention that an FCU creates a 'new circuit'.BS 7671 states "supplied from the same origin and protected against over current by the same protective device(s)." this means adding FCU will form a new circuit ...
it was, and still is a 'final circuit' even after the immersion has been replaced by a socket. I don't see how this helps you to decide whether or not it becomes a 'new (final) circuit' when the immersion is changed to a socket.So for the example given where an immersion heater is removed and replaced with sockets, I think we must accept it was a final circuit ...
As you imply, the guidance in BS7671 says "... The Minor Electrical Installation Works Certificate is intended to be used for additions and alterations to an installation that do not extend to the provision of a new circuit.". As you say, it therefore follows that if the installer issues a Minor Works Certificate he/she believes that they did not create a new circuit. However, the opinion of the installer surely should not be the criterion by which one decides whether something should be regarded as a 'new circuit', should it?However as I said before, it would need a court to decide, so the main thing is if using an installation certificate or a minor works certificate, I would say if using a minor works it is not a new circuit, that does not mean it is a new circuit if using a installation certificate, but if a minor works has been used, it shows the person doing the work considered at the time it was not a new circuit.
I don't think that legislators see it like that. They do their best to write laws which are comprehensive and non-ambiguous and therefore not open to variations in interpretation. It is only because they rarely succeed totally in that aim that courts have to make decisions about interpretation, creating Case Law. A court (i.e. Case Law) cannot alter anything in Statute which is clear and unambiguous - only the legislators (i.e. Parliament) can do that.Most laws are written with the idea they will be added to with case law ...
As we have pointed out to you countless times "Welsh Part P" is identical to "English Part P".... the Welsh Part P leaves very little leeway ...
It would seem that some people would disagree with you - or, at least, would say that subsequent replacement of the socket with some other connected load (immersion, shower, cooker, lights or whatever) would constituter 'creating a new circuit' (because of the 'new purpose').To install a consumer unit with a 13 amp or other size socket supplied from every overload device which can then latter be replaced with another device would not be in the sprite of the law, but I would think it would be a brave inspector to try and take it to court as illegal...
Kind Regards, John
