I have a couple of double radiators that refuse to get hot. The pipe to the radiator is hot. The valve is open. The T-piece connection between the two radiator shells is hot. The first verticall ducting on the radiator is getting warm and the top of the rad is warm, but the bottom of the radiator is almost cold. The radiator is warmer at the top than the bottom! And the spurting from the bleed valve is of a very low pressure. Any thoughts? Thanks.
