Is this door painted with oil or water based paint?
12 Apr 2020
Hi, I need to paint this door, but have no idea if its already painted with Oil or water based paint. Is there an easy way to tell?
If its oil based can I just paint more oil based paint straight on?
And if I wanted to paint water based paint on, would I have to sand it down a lot? Or just give it a key, and then use waterbed primer?
You need to sand it down regardless of whatever paint it already is, and regardless of whatever paint you are going to use.
It doesn't take long, and it ensures a better finish and a much longer lasting result.
Be sure to prime all bare wood, and use decorators caulk in all those gaps to prevent water getting in.
Thanks, do you mean sand it right down back to wood, or just key it well all over?
