Hello everyone,
This is my first post but I have found a lot of valuable advice on this forum so thank you! I hope you can help. I'm trying to learn about the heating system in the house.
There is a hot water cylinder in a cupboard, a water tank in the loft a boiler with a sunvic 207 select programmer which has separate CH and HW timers.
After a series of power cuts in the area, I've noticed the following:
1. the hot water is extremely hot and always hot. This is so even though the switch in the cupboard with the cylinder has been off for months and the boiler programmer for HW is set to off. There is no jacket on the cylinder, I plan to fit one a soon as I understand the system
2.The boiler randomly fires up during the day but especially when a hot water tap is turned on. Even though both the HW and CH is set to off. (I kept it on off for a week to find out whether it was doing this on it's own).
3. After a summer of being off, two of the downstairs radiators are cold. They are fed by the same pipe, but are separated by a wall. The worked on one occasion and haven't come on again so far. The water in the pipe is luke warm but the radiators are totally cold. (I have opened the valves on both ends)
4. The display on the CH and HW programmer has been playing up. It goes blank then comes on again then goes blank. If I set it for a time on CH, the moment it comes on it changes itself to constant and turns the HW to constant too even though it was set to off? The screen is always blank when it is in operation and the only way to turn the heating and HW off is to reset the programmer.
Can you please explain to me how these systems work and how they interact normally and if any of the above mentioned observations are normal? If I need to call a plumber in it would be good to have a basic understanding.
Thank you so much for your help, I really appreciate it
