Building a garden office/music room at end of garden just somewhere i can crank guitar amp up and not annoy everybody i know with crap guitar playing !
It needs to be warm and a bit sound proofed
Got the base down 100mm hardcore/ 100mm concrete with damp proof membrane.
Building a 100mm x 50 mm frame, Which will be clad in 22mm loglap.
Then filled with 75mm kingspan (got cheap from eBay) fill any gaps with expandable foam in a can, then i was going to fix a 50 mm frame on the main frame and fill this with some 50mm rockwool accoustic slabs then fit resillent bars and finish with 2 layers of soundbloc plasterboard caulk all gaps with an accoustic mastic.
The few questions I have are :
1. Do i need a air gap between loglap and insulation ?
2. Where do i put the breathable membrane ? and vapour membrane ?
3. What is a breathable membrane ? (roofing breathable menbrane?)
4. what is a vapour check membrane ?
5. i have been told to leave an air gap in the roof joists between insulation and plywood deck(cold roof) do i need any membranes on roof ?
If i put noggings on the roof joists how does the air circulate around them ? surely the nogging would stop air flow ?
many thanks
many thanks
