Just had a new kitchen fitted with a halogen hob, (4 hob- total of 6.5kw) and single fan oven (2.18kw) fitted directly below the hob.
There is a cooker isolating switch on the wall (type with associated switched socket), not sure of cable size but def bigger then
2.5mm ring main cable.
I was suprised to find that switching off the cooker isolating switch only the power to the hob was cut and not the oven. Further
investigation, by pulling fuses at the consumer unit, confirmed the oven was on the ring main circuit. Don't know how the oven is
connected to the ring main (ie plug and socket) or if it's fused but wherever it's connected it's definitely not accessible. The only way I can isolate the oven from the supply is to pull the ring main fuse.
So my questions are :-
1. Could/Should the oven have been connected to the cooker supply circuit, and what size cable should be used taking into account the power of the hob.?
2. If the oven can be connected to the ring main should it be separately fused (ie plug & sckt) and should this isolating point be easily accessible?
