I am thinking about replacing the floor in my 20m2 living room. The existing floor is pine (laid on top of original floor), which I'm considering replacing with oak. The sound transmission between my flat and the downstairs flat is quite bad, so I'm also looking into some sound insulation.
I have been quoted £3000 (inc VAT) for:
- lifting and removing existing pine floor (but leaving the original floor intact)
- installing acoustic membrane on top of original floor
- installing 9mm plywood sheet on top of this
- resizing skirting and door as necessary
- installing new oak floor on top of plywood subfloor
The cost does not include the new floor planks, which I need to source myself.
Is it a reasonable quote? I am in London, still it seems rather expensive.
Alternatively they have quoted £1600 to sand, repair and re-stain the existing pine floor. However this would not improve the sound transmission problem. (and also as the floor is pine, will probably look very scratched again in a few years).
thanks for any advice you can give!
