Just trying to plan how the electrics are currently set up in my property.
I have identified the ring main serving most of the sockets, and how they flow together by shutting off the mains, removing every socket, and doing a resistance test after connecting neutral to live, tracing each socket until I get to the CU. That's fine.
Following another "pair" of wires from the CU, I initially assumed was on a ring, but tracing the flow in a similar manner reveals that one cable feeds two sockets, and the other feeds a single socket then a small heater in the bathroom. This is protected by a 15a fuse and supplied by 2.5mm cable. I have to upgrade the CU anyway, and will probably create a second ring by completing the two radials, but is it odd to have two radials going off separately from the CU?
