- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
I bought this radiator some time ago but only fitted it a few weeks ago.
The problem is that it leaks from one of the connections into the rad.
I have tried three time now to fix it but it still leaks.
There is now a bubble in the paint work that you can see in the photo.
I have used plently of PTFE tape (is it possible to put too much on?) and carefully screwed it in being mindful not to cross the threads. There is a washer on each connection where I have swapped the washers over just to see if it starts leaking from the other connection but it does not.
Is there anything else I can or should try such as using Fernox LS-X?
Thank you and hope you can help.http://www.screwfix.com/p/fernox-ls-x-leak-sealer-50ml/23614
