I would like confirmation on correct connections from what I understand of posts below.
Setup:
Adding a 2-way switch to a single 1 way light switch. The mains feed comes from the fusebox to the existing light switch first and then on to a junction box supplying 2 off fluorescent strip lights. Within the existing switch box there are 2 cables, one in from mains, one out to junction box. Live wire (mains) is connected to L1 and live wire (JB) is connected to L2. Both neutral wires are joined by plastic terminal strip as is the earth wire. First of all - is this a bodge? Most DIY books say that supply cable goes to the light fitting first, then onto the switch...
However, as I understand the posts below, in order to setup 2 way switching for lights, I should connect wiring as follows:
Within existing switch:
Mains live to existing switch, conn L1. Live out to JB, conn L2
Yellow / Black wire from conn L1
Blue / Grey wire from conn L2
Red / Brown from Common
Mains neutral in, connected with terminal strip, to JB neutral out
Earth in, connected with terminal strip, to earth JB out
Within new switch:
Yellow / Black wire to conn L1
Blue / Grey wire to conn L2
Red / Brown to common
Is this correct? Incidentally, 3 core & earth cable bought at Homebase on Saturday, why black, grey, brown and not yellow, red, blue as all the books show?
Many thanks, Orbster
see forum rules 17 & 20
your post has been split
Setup:
Within new switch:
