I posted a problem that i was having regarding a fused spur that i was going to put in the loft (running from a hallway socket up the inside of the plasterboard wall into the loft to plug in a lcd tv that will be mounted from a ceiling bracket in the bedroom). Well do you think i can this cable down the wall no way. So now i was thinking about running a extension cable instead i.e running it down the inside of the wall drilling a hole below the socket re-wiring the cable and plugging it in there, & then plugging the T.V. on in the loft.
HOW SAFE IS THIS.................................
