Isar Boiler condensate problem
9 Aug 2009
Somerset
Hi All,
I hope that you can help me, the condensate pipe was blocked on my boiler and the engineer disconnected the pipe and let in drain into a bucket, he said he was coming back but has'nt as yet
Is the condensate draining into a bucket an issue as I have no idea what is draining, whether its just water and does it affect the operation of the boiler??
Your help is grately received
on ideal isars the company i work for class it as AR wen the condensate terminates to a open end inside the property (because of the size of the trap)
where is it blocked? i presume its blocked in the pipework after the boiler? if it is just unblock it yourself and reconnect the condensate
Thanks for the reply, i assume it must be blocked after as it is currently draining into a bucket quite happily.
Oh what do you mean by AR?? Im not very technical Im afraid
Arran
AR stands for At Risk - basically they advise ya not to use it till its sorted
where does the condensate terminate?
The pipe that was disconnected runs out the exterior wall, they just put another piece of pipe in at the mo to drain into the bucket under the boiler.
yeah i live in a coach house so 1st floor, just having a look the pipe goes out the wall to a pipe running down the outside wall into the ground. So i assume the bloackage is somewhere in there.
Although it was the fact its been several months since i had the work done that worried me as its still draining indoors, but as long as its not a major issue I suppose its fine
It is a fairly major issue.
If I found this situation, I would have given you a formal document stating that the boiler is At Risk of causing injury or death, and either confirmation that I have turned the boiler off for safety reasons, or that you refused to let me turn it off.
The condensate pipe is directly connected to the combustion chamber, and if the built in safety is not large enough, you run the risk of the boiler blowing CO into the room.
