im having problems with my he30 boiler when using hot water it works fine but when I turn the heating on with the water it goes of and comes up with the F/L FAULT CODE any ideas?
I recon that you need to get a Gas Safe engineer out. Sounds like you min is off (when you run your boiler on dhw it sets your boiler to max which produces a high flame which is recognised by your flame rectification device which allows the boiler to stay on without locking out f/l code. When run on ch mode the boiler reverts to min which if not set properly won't be acknowledged by the rectification device and in turn will cause the boiler to lock out. F/L)
