Hi All
Hopefully a query with a fairly easy solution.
I have a bathroom washbasin with twin taps both connected to copper supply pipes via flexible tap connectors with iso valves. I changed the taps about 2 years ago, but at the time I used a freezing kit on the hot connection in order to change the tap and swap the connector for one with an iso, as I couldn't work out how to turn the hot supply off without draining the tank. Its a conventional open vented system.
One of the replacement taps seized completely a couple of weeks back, so I decided to take the opportunity to fit a pair of lever taps, which would be easier for a member of my family to use because she has problems with her grip due to arthritis. I managed to connect the cold supply without any problems, but on the hot side I've had trouble getting a watertight seal between the old tap connector and the new tap. It may be, therefore, that I'll have to renew the connector.
What I wanted to ask is whether there's a way to isolate the hot supply so I can change the tap connector without having to buy another freezing kit, and without draining the tank. I can see where the hot water supply pipe exits the top of the tank and goes down behind it to join the hot supply pipes at the bottom rear of the airing cupboard on their way to bathroom and kitchen, but there doesn't appear to be any isolating valve.
Thanks in advance.
Thanks in advance.
