I'm running H&C water from under a bath to a cloakroom on the floor above.
Do I need to fit isolating valves to the supply pipes under the bath or is it advisable to?
I am also fitting a closed back toilet which won't allow access to the cold water feed when fitted. Should I position the isolator so I can turn off the supply to the toilet without moving it away from the wall?
Regards,
Jon
Regards,
Jon
