Hello all,
I'm having my CU upgraded(LACB informed), and thought of having an isolator switch fitted. Wondering what is the correct way to isolate the CU from the meter. Arranging the DNO to come & pull service fuse & install an isolator provided by me.
I was thinking maybe a 60amp Wylex switch fuse between meter & CU (as the main DNO service fuse is also 60amps). The cable runs between meter & CU are approx 1/2 metre in length.
The other option is a normal Wylex DP 100a Main switch housed in a IP65 enclosure in line between the meter & CU.
Whats the ideal option..
any help appreciated
thanks
[/url]
thanks
[/url]
