isolation valves
15 Feb 2007
Does anyone know if there is such a thing as a compression fitting isolation valve tap connector all in one?
It would be for standard 15mm copper pipe to 3/4 tap flexi hose connector.
Just seems daft to have to put an isolation switch in line than a compression fitting for tap connector.
Ive had a look at bnq,screwfix etc.but cant see anything available.
Cheers for any info
tip :p dont mess with the isolation screw to much.. After a bit it will leak
