- Joined
- 24 Mar 2017
- Messages
- 3
- Reaction score
- 0
- Country
Hi all
I'm trying to connect a diesel generator to a fusebox that then feeds into what was previously the mains meter, now cut off from the mains, in order to power the lights and plug sockets in a builder's hut on my yard.
I have a 3 pole isolator switch (this one - https://www.motorstarters.co.uk/en/25a-3-pole-sw-neutral-boxed-isolator - the smaller square one at the front, I think the accompanying data sheet covers both models pictured?), but I don't know which terminal(s) on the switch to connect the live/neutral/earth wires to for either the generator or the fusebox.
Can anyone help me out with a simple diagram or straightforward explanation?
Something like
T1- Live (generator)
T2 - Neutral (generator)
etc.
would be great
Also, does the switch need to be individually earthed or will earthing the fusebox be sufficient?
Some additional clarification -
* - The mains power is no longer connected and hasn't been for a long time. It wont be reconnected while this setup is in place. The wiring from the fusebox to the building itself was done by a qualified electrician, as was the wiring inside the building.
* - I'm using outdoor rated sockets/plugs/switches, waterproof where necessary
* - Building regs are not really an issue - the setup is behind two locked gates that only I have a key to and the building itself is not classed as a permanent structure, being essentially a jumped-up Portakabin.
I'm imagining the brand of generator/fusebox really doesn't make a huge difference in how this would be wired, which is a good job because I don't have either of those pieces of information to hand.
Any help greatly appreciated. Ta!
Something like
etc.
would be great
