Last night I heard a dreaded dripping noise and tracked it down to an isolator valve connecting the mains to the cistern on the toilet.
It looks like this: http://www.screwfix.com/p/15mm-isolating-valve-pack-of-10/32802
The water comes in from the bottom and the leak is at the top where the water is bubbling out.
I turned the screw to the off position and that worked to stop the leak (but obviously the cistern no longer fills).
What would you normally do to resolve this?
I'm no plumber, but I've thought about:
- Removing the pipe at the top and attempting to put it back in more securely
- Removing the pipe at the top, buy a new valve and use the seal from the new valve
- Adding some sealant around the top of the valve
- Turning the stop cock (Which can be a bit leaky when disturbed) and replacing the part
- Get a plumber in to solve it
