Hi guys, I have some Ronseal 2 pack wood filler. Recently I used it to fill gaps between skirting on external joints. When rubbing down it was pretty straight forward and looked the part once finished.
Now I was using the same wood filler to fill some screw holes. I left the filler a little proud so that i can rub it down. However when it comes to rubbing down, its smoothen up but you can clearly feel the small patch of filler. Furthermore its not very easy to rub down, I thought it would have been a little more brittle.
Btw i tried rubbing down for a good 10 minutes and eventually got somewhere but it ended up faintly unveiling the screw hole.
Any tips guys?
Any tips guys?
