Three years ago I had the bathroom redone and fitted four Aurora IP65 downlights with LED GU10 spots.
Something like these:
http://www.arrowelectricals.co.uk/c...-downlight-in-satin-nickel-240v-no-bulb-p2474
The GU10 LEDs started failing one after the other intermittently after a few months, mainly flickering and then failing. I had them all replaced eventually and after a few months some of them failed again.
In October last year I bought 4x Megaman 4W GU10 PAR16 240V, which I consider reputable and have used throughout the house. Either dimmable versions in the living room or non-dimmable fitted in two exterior IP65 tube lights. None of these LEDs have failed in over two years. The outside lights turn on every night and are exposed to all weather conditions.
The first "bathroom" Megaman failed in February and I had it replaced, I wanted to believe it was just a bad batch. But now two more lights have failed, within a space of a week. One is totally dimmed and the other one went off.
This is driving me crazy, it is just too coincidental to be attributed to the LED spots. Is somehow the bathroom moisture affecting the LEDs? It is not the ones above the shower going first thought.
Or is the bathroom circuit somehow causing this. I found that the work was carried out by the bathroom fitter, although at first glance wiring and connections appear ok. Shall I measure/test for potential issues?
