Hi there,
I've been having some issues with my Hot Water and Central Heating for a while now and we've had a plumber out twice who seems to fix the problem we were having at the time but then another issue arises soon later. So I was wondering if anyone could advise me to what the actual problem may be?
My Mid Position Actuator is a Drayton MA1 and my Timer is a HoneyWell C21.
At rest the lever of my Mid Position Actuator sits at H.
I then turn on just the water, this leaves the lever in the H position.
Then turning on both (CH and HW) moves the lever to M.
Then turning off the HW doesnt move the lever at all, leaving it at the M position. This also turns off the boiler (The boiler only comes on when HW is turned on).
Turning the Heating off, then returns the lever back to its original position of H. No matter what I try, I cant seem to get the lever to the W position, which means that when I turn the hot water on at the timer, the radiators all heat up. I'm assuming there's some wiring issue or something here or a faulty part? I don't know which part though and I'd very much like to know before I get anyone in to look at this issue.
Hope someone can help me.
Thank you in advance.
