Looking for a bit of advice here.... (as usual)!
Where my walls meet the stairs (stair string ?) I have a nice crack running along it as there is a bit of movement in the stairs. How can I best solve this ?
One of my mates ripped about an inch of the wall out and filled it full of plaster and then caulked along the edge which has solved most of it apart from the bottom part (where most of the movement is). What can I do to address this as more plaster/polyfilla will just crack again.
I can't really run a quadrant bead along as it appears that the width of the stair string seems to change. I have been told to drill it and screw it and then caulk, but in order to get the rawlplugs through the width of the hole is bigger than the screw head so there is now way it would be of any use.
Any advice much appreciated!
Ben.
Ben.
