I have just converted a gravity fed system to a fully pumped. when I first filled it up there appeared to be no flow when the pump was turned on. However, eventually with adjusting pump speed and turning it on and off both the hot water and central heating warmed up. However, the cylinder had developed a leak and had to be replaced and therefore had to drain it all down again.
However, when I then refilled there again is no flow. The boiler fires up and the pump turns on, but the hot water from the boiler is not flowing through the pipe work. The vent from the the boiler becomes hot and of course the boiler stat soon turns it off. There is water in the ground floor radiators but when I try and bleed the upstairs nothing comes out (air or water!)
I would be grateful for any suggestions.
