Hi Guys,
Hope someone can help.
I just bought a house and seem to be having trouble with the hot water.
I have a 'Ferroli Optimax HE Plus 31C' Boiler and a DanFoss 5000Si Thermostat. (Manuals below)
I can't seem to get any hot water unless the central heating is on.
If the heating is on (either by schedule or manual override using the controls) I can get hot water ok.
If the heating is off, I cant get hot water.
The manual says there is 'Comfort Mode' where the water is kept hot awaiting someone turning a tap on or there is 'ECO Mode' which will take the cold water and heat it up on request.
I can't seem to activate Comfort or ECO mode as per the manual though... it just doesn't respond when you hit the ECO/Comfort button.
On page 5 of the manual, it says:
"The Domestic Hot Water heat demand (generated by the DHW flow sensor or due to a Comfort request) is indicated by
the flashing of the Hot Water symbol under the tap (part. 8 and 9 - fig. 1). The display indicates the actual Domestic Hot
Water temperature (part. 11 - fig. 1) and during domestic hot water off time the text “d1”."
The hot water symbol DOES appear when a hot water tap is opened but the water never seems to heat up.
Is anyone able to lend a hand?
Cheers.
Ferroli Manual:
http://www.ferroli.co.uk/wp-content/uploads/downloads/2012/09/Optimax-HE-PLUS-31c-38c-Manual.pdf
Thermostat Manual:
http://www.consumers.randall.danfoss.co.uk/PCMPDF/TP5000Si+RF Easy User Guide.pdf
Cheers.
Ferroli Manual:
Thermostat Manual:
