I have just moved into a new property that has a Istor HE260 boiler installed. I have the user guide and installing and services guide but (and it is probally just me) they don't appear to be written in the clearest of english.
I am trying to user the programmer set up but firstly there are parts of the display that don't appear to be referenced in the user guide, such as the smaller numbers to the right of the larger time numbers and also the R button below the HR button.
What I am trying to do is present the Central heating to certain times, or if I can't do that just reset to the built in default programme.
The user guide states that pressing 'day' flips between a selection of days, but does not say if you set the time per day or you set the times then assign it to certain days. In addition I choose the day select I want (Mon - Fri) and when I then pressed P which I assumed would show me the times for that select of days the tiny arrows representing the days in question jumped from Mon-Fri to Sat-Sun.
Does anybody else have this boiler and can point me in the direction of an easy to use set up?
