... that some people without the slightest grasp of how electricity works try and attempt to do electrical related DIY.
Its one thing to not be sure on the finer points of the regs, or to be unsure whether a certain circuit should be rcd protected or not (taking into account the likelyhood of an earth fault and the likely hood of nusience tripping, as well as the regs), but is another thing completely to connect your switch across your light and be confused when it trips the mcb.
From many replies to these sorts of questions I gather that I am not alone in thinking its worrying issue
Adam
P.S. saying this I did manage to connect a supply right across a room stat once , but that was a case of cable mistaken identity- two cables disappeard (behind pine cladding) towards a fcu needed to re-route one, would be difficult to get it back down to fcu and pine clading was going to be removed anyway, so tried to pull both cables up, the supply cable came, but the 'load' cable didn't, so chopped it off and put it into the fcu (in new location), little did I know that the central heating junction box was a surface mount box with balnking plate trapped behind the cladding and what I thought was the cable going from the fcu to the central heating junctionbox elsewhere was actually the cable to the room stat from the junctionbox
Adam
