Hi - I am living in Spain in a very old building which has been extended in the 1950s. The extension is of a typical pillar and concrete floor type using clay infill panels between concrete beams for the floors and roof. Part of our house is on the first floor where there is no building underneath ie it is exposed to the fresh air and here lies our first problem. In summer the floor is lovely and cool but in the recent cold weather the floor is very cold indeed and makes the heating system struggle to keep the room warm. I had concluded it is necessry to insulate the floor from the underneath and wondered what material would be the best. Our local builder has suggested using 100mm expanded polystyrene foam panels glued to the underside of the roof with the yellow spray-on foam - sounds possible but is this the best way to deal with this or is there a better way?
No 2 problem, there is a 14" ventilated space between the plaster ceiling and the flat roof of the building which has a 2" layer of rockwool insulation inside - however we recently put in recesesed ceiling lights and now get a constant draught from the roof space throught the lamp fittings and are no doubt losing a lot of heat into the void above. Is there a good way of stopping this withough haveing to replace all the lamps - and is there any way of blowing! more insulation (ganular perhaps) into the void through the 12 ceiling light holes?
