I've got a yale HSA3095 with was my grandad who has passed away and we don't know the codes or anything how do we do a factory reset on the System thanks
send me a message with your email address and I will forward it to you
to do this click on my username in the panel to the left of this post, then "start a conversation."
I do not publish my email publicly.
It is a very old system and I have not used it. The telephone alert system may no longer work.
Yoiu can disable it by removing the batteries from the siren unit (installed outside of the house) and unplugging the power supply. The siren is likely to sound until you remove its batteries.
I find it easier to work on these systems if you remove the batteries from the siren and bring it indoors while you reset it. You can put it in a cupboard wrapped in cushions to avoid annoying the neighbours.
