... if I want a few lights, and the opportunity to use a power saw or drill, would it be within the regs to have an electrician spur off through the wall from a socket in the house; run 40m of 2.5mm^2 swa and Bob's your uncle?
Professional responses seem to suggest 6 or 10mm^2 cable
(Confession: before the regs on notifiable work came in, I ran 2.5 mm^2 swa to a Screwfix cu in the garage 5-6m away. Laid in 4 double sockets and a light fitting and connected it to the house cu. Myself! Nothing has burned down or tripped out as a result in 16 years!)
CG
CG
