Jacuzzi Bath
18 Mar 2006
Yes you can use the existing cable if it will fit in the terminals. The cable will be either 6 or 10mm² not 8.
Davy
Thanks mate, really appreciate that advice, that will save me alot of work. ;)
The bath instructions will probably ask for RCD protected supply. If your shower circuit is, OK, but if not, you need an RCD spur. All domestic spa baths I've seen run on <13A supply.
If this is the case, it may be as well to replace the main shower fuse or breaker with 16A.
