Hi, I have a Jaguar 28KW combi.
The temp reading shows 70c, even when the system is cold. The CH will only come on if you turn the temp to max, and when requesting HW, the boiler will fire for a few seconds and then go off, then fire and go off etc and the water is cold or luke warm.
I've done some fault finding and discovered that if you disconnect the CH thermistor, then the readout still shows about 60c and there is no fault displayed. With the CH thermistor disconnected the HW works as normal. The boiler will fire when you switch the CH on, even with the CH thermistor disconnected.
I have checked the resistance of the CH thermistor and it seems ok, there is approx 4.5v to it from the PCB and I have tested the wiring which seems ok.
I'm about to go and fetch a new thermistor, but I'm suspicious it could be something else, possibly the PCB?
Has anybody come across this before?
Mark
Mark
