Hi
I have a Jaguar boiler that has a problem (I know, they're rubbish so what do I expect...). Basically, when the boiler switches on, it 'ignites' for a few seconds, then cuts out. Then tries again ad infinitum. The pressure bar thing is also very high (after draining the system a bit, it keeps rising from 1.5 ish to about 4.0).
British Gas have been out three times to try and sort this out, and everytime it works for a few hours after they've been and then it all starts to go wrong again. On their last visit, the engineer pointed out that the valve on the filling loop was the wrong type (apparently it's a mains valve). I've noticed that when I drain some of the system and dropped the pressure back don to 1.5ish, the boiler seems to work okay - until the pressure reaches 3.0+.
What I want to know is:
Could the incorrect valve on the filling loop be causing the pressure to constantly rise?
Is this probably causing the boiler to stop working?
Is this something I could fix myself and if so, how?
It's very cold in my flat, and I'm having to use a kettle/friend's houses for hot water. Any help would be greatly appreciated.
