Jaguar Boiler Pump
16 Jan 2009
London
Hi, I'm in urgent need of a replacement pump for a Jaguar 23 combi boiler. The Part Number is : 0020023217 I'd be really grateful if anyone has any ideas where I can get one of these quickly in the London area?
PartCentre don't seem able to get one, it's always due "tomorrow"
or Does anyone know any alternative pumps that can be used, I understand that Glow Worm are the sapres supplier so I wonder if any of those pumps would fit.
Thanks.
I;m fairly sure the Jags used a standard grundfos pump. check what it says on the pump, it may say 15/50 or 15/60. you can buy a standard grundfos pump and just change the head.
it's a special Wilo. ;)
ooh poo, slapped wrists for me. :oops:
so a normal wilo head won't fit then?
I've tried a standard Wilo and the impeller gets jammed tight against the body. :(
Learnt this the hard way.
well looks like you learned for me cos i would have tried it too ;)
ta :)
ta :)
when you look at them bothg in your hands you'll see the impeller is different and the shaft is longer in the standard wilo. ;)
I changed one with a Bg standard pump head - with a slight mod on the alignment nib if memoery serves.
Trouble is can't remember who makes the pumps for Bg now???
Anyone know??
Al
bg use pumps made by both Grundfos and Myson (or whatever they're called now).
