I've got a jaguar 23kw combi and my hot water goes on and off constantly when running hot tap up or down stairs consequently water runs hot and cold also never seems to get that hot anyway. Any clues????
unfortunatly i have a jaguar 23 that has had this fault. ie the hot water turns on and off and the only way to get any temperature is to turn the tap off abit makeing it all but useless. the problem is that the jaguar boiler has a secondary heat exchanger in the back of it that blocks with scale, this reduces the flow through the exchanger tripping the overheat switch then as the cold water re sets the trip the boiler starts again and so on. i have removed and cleaned the secondary heat exchanger many times on my boiler and cleaned it out ,it is a pain but it works.[/quote]
All of you with blocked plate HEs have to understand that the Jaguar boiler was sold cheaply and was always fitted without cleaning the rads so the rusty dirt migrates into the plate HE and blocks it.
Thats not the boiler's fault, its the fault of the property owner at the time who had them installed cheaply often by builders.
i dont disagree with you Tony ,they are a good boiler when allowed to be,but unfortunatly they just find it very difficult coping with an old system,i flushed mine and used the concentrated pipe cleaner but still had problems with pipe scale not rad sludge .its a shame an in line filter of some sorts isnt available ,there would b many fewer people on this site if there was. Gary
