JG guest conduit
18 Jul 2019
Slovakia
Hi, I am going to run jg guest coil pipe through conduit given it will be set in concrete etc. Actually it will be under concrete, not actually in the concrete. So I was wondering if the conduit jg guest have, is it some special plastic? Or is it basically just a 'normal' plastic conduit similar to conduit that electricial cable goes through. I'm happy to buy the if guest stuff, but I don't want to have to wait for delivery to Europe etc only to find it is garden variety conduit and I could of bought the same stuff from my local building supplier.
If anyone has feedback on this matter it would be appreciated.
The pipe will be under insulation and then the screed on top....I want the pipe in conduit so I can pull it out if need be and replace it etc
Up to you my friend but I doubt you'd need to replace it... All one length with no joins, it should last forever... UFH pipes are the same and they're laid directly in the screed. Personally, I'd go for Hep over JG as I prefer the product but they're both good for long guarantees if installed correctly.
Thank you for your feedback, it has been taken on board, but I still would like to know if the jg conduit is something special or basically ordinary plastic conduit
