I notice that JG make tap connectors in both plastic and brass versions:
http://www.speedfit.co.uk/Home/Prod...22mm---28mm-Sizes/STRAIGHT-TAP-CONNECTOR.aspx
http://www.speedfit.co.uk/Home/Prod...8mm-Sizes/FEMALE-COUPLER---TAP-CONNECTOR.aspx
What's the benefit of each? Obviously brass is stronger than plastic but what's the benefit of having a stronger tap connector if everything downstream is plastic anyway?
