Hello
Please advise me, is it safer to use speedfit pipe with compression fittings rather than the usual plastic fittings?
It just strikes me they are likely to last longer because they rely on an olive rather than a rubber seal which eventually degrades?
Some of my fittings will also be under a little side pressure because of the awkward routing and flex in the plastic pipe and so maybe compression fittings would cope with this better?
