We've got an extension job at work, shell is up and first fix is about to start.
The plans state interlinked smoke alarm's with battery back up to be installed if not inplace already.... (which they're not)
The consumer unit is the old style wylex (5 way i think from memory), which looks like it'd have ones had semi-enclosed fuses, but've been changed out for plug in MBC's. This board has no space left in it.
Am i right in thinkin' that the smoke alarm's need to be on their own circuit? (As i know this is how we were doing them on our newbuilds.) If so, that'll mean an update of consumer unit, at which point then..... Don't all circuits being connected to it, have to conform to latest standards/regs?
Which is then where it's gonna start getting expensive.... the main earth's aren't 10mm, meter tails aren't 25mm.
I'm also pretty sure that all the sockets currently are on a single 30amp breaker, would this need splitting?
(All work will be checked by LABC as the job won't get signed off without certification.)
Cheers in advance.
Cheers in advance.
