Joining 2.5mm 3 core under floorboards (inaccessable)
23 Jan 2003
Hi, could you please advise me?
I am moving a partition wall and need to move a socket (that is a spur) to allow this. This involves extending the spur by means of a junction box under the floorboards which will be inaccessible once the wall is moved.
I went my local electrical wholesaler who didn’t seem to understand why I wasn’t using a standard JB with screw terminals! This would be simple, but I believe I cannot use one of these legally. Am I correct?
I have seen wago connectors at Screwfix and think this is what I need i.e 3 connectors placed in a wagobox.
However, I am confused by one of the Q&A answers on the Screwfix site:
Q: Can this box be used for a ring main?
A: Yes the junction box can be used on a ring main, if accessible.
If the box is not accessible, then you would need to used 2 of these boxes to met the max aggregate current for this box in maintenance free applications.
If unsure in anyway, please consult with a qualified electrician
If I am simply connecting 2 pieces of 2.5mm 3 core so I don’t need 2 boxes do I? If so, how does this work in practise??
Also, which connectors should I buy? The 222 rated @ 32A?
Any advice appreciated, Thanks
Hi
Terryplumb, I would but I don't know where the cable is spurred from
Riseard, not seen these before. Look like the solution in one unit
Thanks both
